PRIME X670E-PRO WIFI
Sergji
Hello, I was wondering. Will there be any problems if I take this memory + processor kit?
G.SKILL Trident Z5 Royal Neol Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J2836G16GX2-TR5NS
And CPU
Ryzen 7 9800X3D
Will everything work well?
Thx
Jiaszzz_ASUS
Hello @Sergji
Thank you for reaching out to us.
May I confirm if you have already purchased the motherboard and related components? Are you currently experiencing any issues during use?
Regarding memory selection, ASUS has verified the motherboard for optimal stability and compatibility with devices listed in the CPU/Memory QVL.
We recommend referring to the memory QVL for the PRIME X670E-PRO WIFI, as well as the purchasing and installation guide available on the same page.
Please also refer to [Motherboard] How to query (CPU/memory) QVL List? if needed.
