12-28-2023 05:22 PM
I have a ROG STRIX B350-F GAMING motherboard and inside I have a Ryzen 5 2600x CPU. I wanted to upgrade for a while but I didn't know where to start so I went to some friends and they said the motherboard couldn't support higher CPU's but then I came here and looked in my motherboards page ( https://rog.asus.com/motherboards/rog-strix/rog-strix-b350-f-gaming-model/helpdesk_cpu/ ) it's showing a bunch of higher end CPU's being compatible with my motherboard. Who do I trust and take the info from in this case? because I really need to know how much money I need to save.
01-01-2024 06:19 PM
Hello, @TonkaTruck
Regarding the selection of a CPU for the motherboard, please refer to the support page on the official website under the specific model > CPU/Memory Support > CPU Support section for the list.
This model supports the CPUs specified in the CPU QVL, and there are corresponding BIOS versions that commence support.
For example, the Ryzen 5 2600X is listed in the ROG STRIX B350-F GAMING QVL, and it is supported beginning with BIOS version 3803.
Please refer to [Motherboard] How to query (CPU/memory) QVL List? for more details.
01-05-2024 07:48 AM
Make sure you update your BIOS to the latest available version before you upgrade your CPU.
