aRGB case fan question
lmacmil2
Is the addressable gen 2 header on my B760M-A motherboard where I would plug in an aRGB case fan connector?
1 ACCEPTED SOLUTION
Accepted Solutions
Hello @lmacmil2
Thank you for your inquiry.
Generally, it is indeed possible to connect the device to the 3-pin Addressable Gen 2 headers.
However, please ensure not to daisy-chain too many devices, as this could exceed the power supply capacity.
lmacmil2
I ordered an aRGB fan so I will find out the answer to my question next week.  I'm pretty sure the answer is yes.
Hello @lmacmil2
