ProArt Display PA279CRV FIRMWARE
dpraz
Hi, is it possible to update the firmware of the ProArt Display PA279CRV?
"BIOS&FIRMWARE" tab doesn't even exist on the official support page for this model.
Aureliannn_ASUS
Hi @dpraz ,
may I ask if you are currently experiencing any issues with your monitor?
Please provide a detailed description of the situation in which the problem occurs, and we will assist you in diagnosing the issue.
Hi. Thnx @Aureliannn_ASUS.
When I move the mouse, there is a recurring slight flashing effect. Not always, but when it does it is distracting. As I read here, this is not a rare occurrence, but it has been fixed by a firmware update. Unfortunately, the PA279CRV model does not have this option or I have not seen it.
macOS Sonoma 14.5, Adobe CC, Figma, MacBook Air M1, MacBook Pro M2.
Thnx
