Connexting a latop to a monitor
PopsScott
Hi guys. So I want to buy a monitor to game on and i think I found the best one for me but I am not really sure if my laptop will support it . The monitor that I want to buy is an Asus VG27AQ 2k 27” and the laptop that i have is
Laptop ASUS Gaming 15.6" TUF F15 FX507ZM, FHD 144Hz, Procesor Intel® Core ™M 17-12700H (24M Cache, up to 4.70 GHz), 16GB DDR5, 1TB SSD, GeForce RTX 3060 6GB .
Also I can only connect them with hdmi . So what do you think is this a good choice for my laptop ?
Aureliannn_ASUS
Hi @PopsScott ,
based on your question,
it's important to consider whether your laptop's specifications and HDMI connection can fully support the monitor's capabilities.
For Asus VG27AQ, supports 2K resolution at a higher refresh rate of 165Hz. Selective graphics cards/GPUs can support 165Hz graphics source output (DP port).
You can refer to the following product specification of the two products.
ASUS TUF Gaming F15 (2022)|Laptops For Gaming|ASUS Global
TUF Gaming VG27AQ|Monitors|ASUS Global
