Any way how to fix brocken acreen
King114
I wake up and ffound it like that any help??
Aureliannn_ASUS
Hi @King114 ,
based on your issue, it is suggest that you can reset the screen to default settings.
You can use the monitor control panel to set the monitor back to the original factory defaults.
Please press the Menu or 5-Way button on the back of the monitor to activate the setting menu.
You can refer to the troubleshooting steps in the below link.
[LCD Monitor]Troubleshooting - Picture or Text blur/Display Position or Resolution not correct/Scree...
And make sure that the graphic driver is at the latest version.
Also, could you provide the product model?
