Power Passthrough option for ROG Phone 2 Android 11
Ruby8
Can you please add the capability so user can have the option to plug in the charger cable and have the battery not charge and instead the phone only is powered from the cable? Thank you so much 🙏
Aryan202
Community Legend I
If I recall correctly the official response was that newer Rog phones (R3/R5) have a special type of circuitry to bypass the battery which Rog 2 lacks
So seems like the feature is a combination of hardware+software
