Zenfone 5Z Mobile Radio Power OFF
chrymt
Hello Friends,
Suddenly I lost Mobile network and calling facility on my Asus Zenfone 5z. I recently upgraded to Android 10 so I thought it is a bug. But I did factory reset and even downgrade to Android P by following guidelines in Asus website but Mobile network issue persists. I can't call or use Mobile network!!!
The SIM perfectly works in any other phone. However if I put any SIM in my Asus Zenfone 5z the issue remains same.
After dialling *#*#4636#*#*, I found Mobile Radio Power is OFF. I can easily toggle it to ON but it reverts back to OFF immediately. The issue persists even I restarted my device in SAFE mode, turning Aeroplane mode ON/OFF every possible option.
Currently I again upgraded it to Android 10 but same issue.
Any help?
6 REPLIES 6
AmitGarde
Community Legend II
Muheet
android 10 latest update ....asus 5z....same issue here.....i reset the networks after reseting i lost networks....it is coming and going...networks are on or off......unstable i tried evwry ppsible option factory reset.....now i dont knw what to do...i m frustrated.....please anybody has solution will b appreciated.....please let me know if its software issue or hardware....thanks
After trying various several steps if your issue still exists than it seems its most probably hardware issue as antennas may have been loosen up having connections with sim tray
I recommend you to kindly take your device to nearest service centre for examinations and fixes
Note:- dont forget to backup your imp data before you submit your device to service centre
thanks! 😊
vineet_ohol
same issue since 2 weeks. its as good as i dont have a mobile phone. I have spent so much time to get a fix but nothing works. ASUS has proved to be a poor decision to own. i have a 5z. I am always going to steer away from every electronics that has direct or indirect relation to people who cant open their eyes wide
