07-19-2019 06:24 AM
07-19-2019 09:49 PM
07-25-2019 09:41 AM
Try doing this..kasibhatlasuresh said:Hi, since last I week my phone is not detecting 4G data network. I have tried to restart, remove card and reinsert and check all settings but the problem is still not resolved.
07-28-2019 06:25 PM
hey good day... i had that problem setting to LTE only... whenever i tried to set it to LTE only, nothing happens. it just go back to normal settings... i'm using zenfone max pro m2..Sufyan said:Try doing this..kasibhatlasuresh said:Hi, since last I week my phone is not detecting 4G data network. I have tried to restart, remove card and reinsert and check all settings but the problem is still not resolved.
Open your dialer type *#*#4636#*#*
As you enter this in your dialer a settings menu will show up you have to tap on the first option which will be "Phones information"
Then you will see something like "Set Preferred Network type
Tap on the box below that and look for LTE only and select.
But remember this will set your phone to only lte so until you are on that setting you will just be able to use data and won't be able to make calls or receive them so whenever you are done using your data in 4g you can just turn on aeroplane mode for a sec and then turn it off that's the easiest way to get back to the normal settjng.
I hope this helps you if it does like my comment 😜
Have a great day
