How to Solve Asus Zenfone 9 Speaker Sound Issue After Calls
miyaroy
If your Asus Zenfone 9 speaker isn’t working after calls, don’t panic! First, restart your phone and clear the Phone app cache. Also, check Bluetooth and “Do Not Disturb” settings. Sometimes, a simple software update solves this issue. You can also try using the  Fix My Speaker Tool to remove hidden dust or water from the speaker by playing sound waves. If the problem still exists, back up your data and perform a factory reset or visit a nearby service center for professional help.😊
0 REPLIES 0
