Side charging port has become primary connecting port for data transfer, Android Auto
  1. Model Name: Asus Rog 5
  2. Firmware Version: 31.0810.1226.91
  3. Rooted or not:not
  4. Frequency of Occurrence: 10/10
Side charging port has become primary connecting port for data transfer, Android Auto and when charging with different charger. Primary port has become use less
Comments
  • Hi Punisher100192,
    Please run SMMI test to check whether this is related to hardware/software.
    How to Enter SMMI_TEST (test hardware)
    Go to Calculator=>type " .12345+= "
    you will be entered to SMMI_TEST
    Select AC charging test under Single test.
    If found any fault, please visit the nearest service center.
  • I already did it, it started happening at an update. When I bought the phone on January it was working fine.
  • The same problem I heard when I was watching this video https://youtu.be/6pf2KJD5qf0
    Start video from 12:00
Sign In or Register to comment.
