06-25-2021 12:54 PM - last edited on 01-16-2024 01:43 AM by ZenBot
06-25-2021 01:25 PM
dijilkavattuI suggest you read this guy's post and see if it helps:Battery draining fastly by playing videos ,games and during calls . standby is okay there is no draining.i tried safe mode there is no problem and i reset the phone but still the draining issue is going on .in the last update is done this problem comes and also microphone phone volume is very low
Battery draining issue
Shivam DahiyaAre there any suggestions regarding battery drain . Everything was fine but nowadays it's draining like way too much . It went from 94 percnt to 68 percnt in 1 hour and 35 minutes seriously just by playing ludo 🥺. I think my battery calibration is not fine , despite charging it for 15 min extra after 100 it goes to 99 percnt with a few seconds . Kindly drop your suggestions below thankyou .
Suggestions to stop battery drain
06-25-2021 09:34 PM
06-27-2021 11:20 PM
dijilkavattuBro I had similar problems in standby mode too , but they got resolved after a force shutdown . Try to restrict instagram from using data in background might help you and regarding games cn not say much but try avoid playing games when battery as low as 20 percnt. Try extreme and smooth settings too , if you are at 90fps then it will drain faster than normal usage also try playing without Xmode might get some help . Also set the display refresh rate for game from armouray crate, 120 will consume the battery most .Battery draining fastly by playing videos ,games and during calls . standby is okay there is no draining.i tried safe mode there is no problem and i reset the phone but still the draining issue is going on .in the last update is done this problem comes and also microphone phone volume is very low
