05-21-2021 01:51 AM
05-21-2021 03:32 AM
ramneek2110I have discussed this earlier many times but unfortunatly this will not be fixed. They said that it is just sync issue and nothing else, battery drain has nothing to do with this sync issue. And also want to inform you that active support for 5z is ended now.Please tell us some basic information before asking for help:
- Model Name: Zenfone 5z (Asus 5z)
- Firmware Version: Latest January 2021 patch
- Rooted or not: No
- Frequency of Occurrence: Everytime
- APP Name & APP Version (If your issue relates to the app): Settings and Battery usage
As you can see from the screenshot attached, the phone is charged and yet it's showing 'charging' in this Battery usage. Is this the really cause of battery drains hell fast from 100% to 95% in just mere 2-4 minutes?
Whatever the case maybe. The Battery is also isn't impressive since the recent updates where 'Android system' for some reason is always the most consuming Battery (as seen in battery usage) and above that is all the apps and services.
Battery at 100% still showing 'charging' in Battery Usage
05-24-2021 02:58 AM
