Drain your battery to zero percent and then charge your phone to 100%. Once 100%, let it discharged by 1% (discharge to 99%), and then charge your phone to 100%, leaving on 100% for at least 15 minutes.
Please also provide more information:
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Comments
Hey Vaibhavbalotra,
Can you share the SOT(Screen on Time) after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
I just saw your reply.. I'll try this now and will revert back the feedback asap.
