(Max Pro M1): After Remaining 10% of Battery Charge...PUBG MOBILE Starts Lagging
- Model Name: Asus Zenfone Max Pro M1
- Firmware Version: 084
- Rooted or not: no
- Frequency of Occurrence: Everytime
- APP Name & APP Version (If your issue relates to the app): PUBG MOBILE.apk
@victinhodesouza when i playing PUBG MOBILE At nearly 11 - 15% PUBG MOBILE works fine... But the Battery percentage touches to 10% then the PUBG MOBILE starts
1. Lagging
2. Frame Dropping
3. Distortion Audio
5. Buzzing Sound
4. PUBG MOBILE UI is Running in Smooth manner... But the gameplay was Lagging...
1. On this 1st video... It shows that the UI Of PUBG MOBILE At below 10%, it was working fine and running smoothly
2. And on this video, it shows how the gameplay was lags... On below 10% of charge... If UI Is running smoothly why not at the time of playing games...
Think about it
I will definitely say that it was your software problem... So, please fix this problem ASAP And Make And Push A Proper System Stability Update For Asus Zenfone Max Pro M1
Thank You
Tarun Dalai
Comments
@Victor0_ASUS please see this post
Every android phone throttle's down the processor of the device when the battery percentage is below 10 percent, to extend the battery life. So don't worry it is supposed to happen.
Okk... Bro
