I had to charge my phone 2 times in a day after using less than 5 hrs
- Model Name: asus rog 3
- Firmware Version:
- Rooted or not: not rooted
- Frequency of Occurrence: evry day
I used my phone to play ping for 1 hr and used it for other apps like what'sapp and Facebook for another 4 hrs by then the charge level was at 10% it drained 90% in just 5 hrs pls help
Comments
Could it be because I'm in developer mode ?
Or is it because of Google Play services
Pls check which apps were running in settings battery menu. You should be able to see apps and their run time and battery drain percentage similar to the screenshot I attached here.
Well a large chunk of the lost battery is missing
But is there any better way to save battery my brightness Is the lowest possible refresh rate is 60 hz wifi &4g off but it is still burning fast
I faced the same problem. i got mine from flipkart. after i factory reset the phone it got fixed
I had faced the same issue. I left my phone throughout the night and it drained 40% in standby. I tried to fix it by factory resetting my phone and it didn't work
I have the same problem of battery drain.I came to know that this is because of the latest update .
This is my usage history.
Asus help !! Pls I have to charge my phone 2 times a day, I mainly brought this phone cuz it has a monster battery
Hi @Riaan,
When you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Also make sure your phone is running the latest software version.
This is my battery at 10 %
@Riaan From 100% to 10% in 5hrs time feels like u need to replace
Ya well i hope the battery is not damaged and its some software bug but we will see
Try factory reset and see if u still see same thing
I'll try
I noticed the more I tried to save battery, the faster it went.
Try charging it with fast charge while the phone is on, set refresh rate at 144hz and like 20/25% brightness. I swear, since when I raised my refreshing rate, battery lasts two full days with intensive using during the day (ex. Today I turned it on, full battery, at 8am. 144hz, at least 50% brightness cause I was outside, 4g on until 3pm, then back and forth from wifi to 4g. I used it really a lot, so the screen was on and working most of the time until now, and now is still 62%)
It may take a few days to adjust but it works, or at least I hope it works for you too!
Try not to save battery. I know it sounds like a paradox but it worked for me.
Fast charge with your phone on, 144hz and 20/25% brightness. It may take a few days to adjust but it seems like it worked for me.
Today I used my phone really a lot and most of the time I had my 4g on, and now it's still 61%
Hey never mind I got it I had a virus or something that was eating battery life thanks guys for all the help
Wait even after factory reset the battery is still being burnt very fast
I have similar problem of fast battery draining issue. Even with normal usage like surfing and youtube videos , it drains fast.
If you set your phone to the lowest settings to save battery, try to put it on 144hz.
Inexplicably my phone lasts way more if I don't try to save battery
