Enquiry about max pro m1 update
- Model Name: Max pro m1
- Firmware Version: android 8.1.0
- Rooted or not: no
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
I just bought a new max pro m1. It came with android 8.1.0. A new update notification for android 9 (.053) has come. Please users reply me whether updating is worthy. Are there bugs? How is the battery drain? How it affect performance? etc.
New question: Is there any way to hide the update notification?
1
Comments
update it, its good
thanks bro 😊
don't update brother
Update up to april. May has a "battery drain" bug.
Do not update. Just wait the Android 10
why bro?? whats the problem
thanks bro 😊
Ok. Thanks for the suggestion 👍
There is no problem you can proceed with the update.
After you updated your phone you have to check for an update again because the latest version is .82
no seriously. Are there any problem you are facing like battery drain, bugs etc..?
Sound quality via earphones?
I don't have any battery drain and there is no big bug's in the latest version .82
thanks bro 😊
Ok thanks 👍
