Why back rgb led is not available for use except lighting case??
i dont understand the thought behind this... why rgb led is not available for normal use as it is a cool thing a phone should have.... dont understand the concept behind it?
Comments
If you go to the Armory Crate and press on Console tab.
On the right hand side, scroll all the way to the bottom, and press on Advanced Settings
Scroll a little down to where it says Atmosphere lighting, you can have different settings for the RGB light for different case,
I hope this helps.
He asked for 2nd RGB flash. Not the RGB ROG logo.
Asus sole intention is to sell more accessories with these type of property hardware tricks. But failed miserably because most of the accessories aren't even available to buy, at least here in India. Yeah I wish they enable RGB LED for normal use too.
Where do you find it on the phone?
Right below the Single LED Flash light. Next to the camera
Ahhh, thanks!
try .12345+= in calculator smmi will open then use single test and scroll down till bump light .... check it it out.
Sorry to ask, but this is weird that you haven't noticed it all this time? 🤔. You're ROG Phone 2 user right?
I am indeed a ROG user, started using it since January. I came from Samsung from S6 to S10 and I thought I would try something new. Before Samsung, I was using Sony Xperia. All past devices were rooted in the end due to it either out of warranty or no longer have OTA updates anymore.
I did notice about the 2nd LED but didn't know it was RGB lighting nor I was curious too lol. I guess the first thing that come to mind for the LED RGB lights is a room with disco lights :')
Thanks for that!
I too was in Xperia family from beginning, from Xperia Neo V to XZ2. Until they discontinued in my country. Everything was perfect with Xperia in my liking.
I've requested this feature long time back, but they have not responded with anything
Till now, not even one user request was implemented or considered. Not even one!
We need to save new features for bigger updates because of limited resources. I would also prefer to push them out regularly so every update is a fun update but if we add a new feature now, then we need to rewrite it for next version of android and test it all over again. It's twice the amount of work, if not more. This is the reason
Well this was the response I got from Mod regarding new features.
What sort of a crooked logic is this ? and what special feature did they add in A10 that was not present in A9 ?
Battery drain and overheating, two biggest changes they have added in A10 which were not available in A9
By that logic, A10 should've came with a whole lot of new features. All just lame excuses to cover their lack of resources in Mobile department.
