Hi, kindly check with your network operator if the voLTE is enabled on the sim card.
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
Yes I have face same issue in my Asus Maxpro M1 , I have vodafone 4G Sim , but vodafone volte not working in asus MAXPRO M1. Vodafone volte is a;ready activate in my vodafone number.
I request you to please solve this issue asap because I purchased this phone is dual volte , but currently is not supported.
How to open mobile in safe made i am facing prblm with jio sim jio network is not showing if network comes then stable not more then 30 second i had reset my mobile after clicking volume up button +power button but did not get any solution
I am facing with jio sim i have done factory reset but prblm was not solved even in safe mode prblm is not solved and this prblm is startet after update from 1 week and i reset data facctory reset and 1thing is left clear system cash how can i do it and when next update will arive to fix this problm
Comments
facing same issue please fix it next update
all asus zenfone max pro m1 model facing same issue
Yeah I have problems with Airtel volte
And no Airtel wifi calling
please fix all bugs next android 10 update
asus bugs number 1 brand
Go can go to safe mode by holding the power off above the restart symbol.
If you want to go back to normal state you can simply restart your phone.
Hi
My airtel volte not working but when I was insert another airtel sim into my mobile then volte working properly.
And my same airtel sim card insert into another phone then also volte working properly.
Even i was change my sim card also.
Same issue happed
For solving that I was factory data reset of my phone but sill issue was going on
My phone is Asus max pro m1
Vodafone volte is not working properly
I am also facing the same issue for some days after that I have done reset, wibe clear cache to
my phone now vodafone volte is working normally...I am using Asus xenfone max pro m1 with android 9 version .82
dial *#*#4636#*#* in ur phone
click on phone information
click on set preferred network type
choose LTE only
i think now ur problem may be fixed
please send android 10 stable update this months
please asus please
My idea sim is not showing volte in my ZENFONE max pro m1 what should I do?
