05-28-2020 11:23 PM
06-14-2020 04:27 AM
06-14-2020 11:36 AM
victor2020How to open mobile in safe made i am facing prblm with jio sim jio network is not showing if network comes then stable not more then 30 second i had reset my mobile after clicking volume up button +power button but did not get any solutionHi, kindly check with your network operator if the voLTE is enabled on the sim card.
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
06-14-2020 12:17 PM
dsingh159@gmail.comGo can go to safe mode by holding the power off above the restart symbol.https://zentalk.asus.com/en/discussion/comment/85245#Comment_85245
06-14-2020 12:31 PM
tusharguin29I am facing with jio simfacing same issue please fix it next update
all asus zenfone max pro m1 model facing same issue
06-14-2020 12:37 PM
victor2020I am facing with jio sim i have done factory reset but prblm was not solved even in safe mode prblm is not solved and this prblm is startet after update from 1 week and i reset data facctory reset and 1thing is left clear system cash how can i do it and when next update will arive to fix this problmHi, kindly check with your network operator if the voLTE is enabled on the sim card.
