Bootloader unlock problem Asus Max pro m2
- Model Name : Asus ZB630KL
- Firmware Version: pkq1.ww_phone-16.2017.1912.072-20191125
- Rooted or not: Non Rooted
- Frequency of Occurrence: pie 9
- APP Name & APP Version (If your issue relates to the app): Unlock device tool
In asusaofficially guvendthis app on website.dition to information above, please also provide as much details as you can, e.g., using scenario, what troubleshooting you've already done, screenshot, etc.
Comments
use the method in below url to unlock Boot loader Unofficially
https:(slash)(slash)forum.xda-developers.com(slash)max-pro-m2(slash)how-to(slash)unlook-bootloader-root-asus-zenfone-max-t3885457
Replace (slash) with the symbol /
yesterday i did the same and unlocked successfully
@Shahed ... You may follow this link as @vckanandvpp has successfully unlocked his Max Pro M2..
Hi, you will not get updates via OTA if you unlock the bootloader, It's better if you keep your bootloader locked, your warranty will be void as soon as you unlock the bootloader. It does not necessarily mean that you are rooted, the bootloader can be unlocked without rooting but the processes go side by side. You will not get any benefit if you unlock bootloader and do not root.
If bootloader locked, we will get buggy software with 3 months per update and also some user experience boot loop after updating latest pie. So this is the benefits from your side to make boot loop the device with no service center nowadays 😡😡😡
After unlocking boot loader , I installed Pixel experience ROM and now i got may security patch with bug fixes.
At present low call volume and Wifi disconnecting automatically get resolved.
One happiest thing is that we are getting OTA notification on the Pixel experience Build and we have Incremental Builds too to download it manually.
With all these facilities why we need to wait for these Lazy ASUS to provide updates. If your mobile is out of warranty , then there is no negative in unlocking boot loader. After boot loader unlocked i am using PayTM also on demand(Install and Configure when needed)
Enjoy with custom rom 👍
How to lock the bootloader in ASUS Zenphone Max Pro M2?
Model Name : ASUS_X01BDA
I install the unlock bootloader apk from ASUS official website.
I didn't install TWRP and didn't install any coustom rom.
Please tell me how did I lock the bootloader.
Please reply me as soon as possible.
