Battery charging and phone heat up
rp_kumar2830
After the recent update, the asus zenfone max pro m2 is getting heat up while charging and the charge doesn't move further 69, 71, 80 % it blinks green light and doesn't charge then. And some times it reverse charge means drains the battery while on charging.....do fix the bugs mentioned as soon as possible.
AmitGarde
Community Legend II
rp.kumar2830
Doing factory data reset will solve ur problem probably give it a try by backing up all your data
kennneth241
Do you think it's all about update?
