Fan problem
System: Windows 10
Battery or AC: Battery
Description: Fan Issue
Model: UX533-FD
Frequency of Occurrence: Always
Reset OS: No
Hello folks,
I've got a Zenbook UX533-FD and the fan is staying on for long periods of time and not going off. Can someone advise me on how to rectify this issue?
Best Regards,
Kevin.
Model: UX533-FD
Reset OS: No
Hello folks,
Best Regards,
Kevin.
Comments
Is the heat radiation fine? or any other abnormal when using it?
You may double check if there is anything running in the background.
Nothing abnormal. Is there any BIOS updates that may help rectify this issue?
Can anyone help on this ongoing issue?
Can anyone help with this issue?
@Blake_ASUS @ServiceH_ASUS @Y_ASUS @STARRAIN_ASUS @Falcon_ASUS @ServiceE_Asus @ServiceC_ASUS @Christine_ASUS @AnthonyLee_ASUS @Joe_ASUS @cael.gfilho @Kris_ASUS @CH_ASUS @VanillaTestER
Can one of you help with this ongoing problem?
Hello tibby64,
As we have been discussing this topic on and off for almost a year,
are you willing to provide more information about the fan or send the device to service center
to let us check for you now?
@Blake_ASUS What information do you need exactly?
Hello tibby64,
well...I have been asking for a video record since the very beginning.
Then we would know under what kind of loading, how does the fan work.
