Conexant Audio Driver Installation Fail
System: Windows 10
Battery or AC: Battery
Description: Windows 10 Pro 1903, 8GB Ram, i7-4510U 2.00Ghz (4 CPUs), Intel HD Graphics Family, NVIDIA GeForce 840M 2GB
Model: UX303LN
Frequency of Occurrence: Always
Reset OS: Yes
So from nowhere my internal speaker and audio jack stopped working. While my HDMI sound output was working perfectly that uses Intel Display Audio.
I completely uninstalled the conexant audio driver and deleted the driver installation files. Navigated through Asus website to driver download sections. I choosed my CPU model and downloaded the conexant audio driver files to my laptop.
When I try to install the driver I get the following error.
Driver Installation Has Failed: Could not find the device for this driver.
I also tried reinstalling the Intel Chipset Driver and the Power Management Driver.
Could someone please help me?
Model: UX303LN
Reset OS: Yes
0
Comments
Please look in to your "Device Manager"
is your built in speaker listed there?
If not, please kindly back up your device
and send it to local service center.
Thank you for messaging us.
Have a nice day.
ASUS Vivobook S15 S510UN
Model - X510UNR
Windows-10 64-Bit
Currently I have no default audio device listed in my playback devices in sounds. See the attachment. When I tried installing the driver from ASUS website - it has the same error 'Driver Installation Failed - Could not find the device for this driver'
I have this same problem; cannot install conexant audio driver for asus laptop, model x555q. Did you come up with a solution
Use .inf file to install driver using device manager.
Some times setup.exe will stop if incompatibility problems.
