08-11-2021 07:28 AM
08-13-2021 12:27 AM
Kuis Kiske@Kuis KiskeIn many asus smartphones, the Asus Zenfone Max Plus M1 ZB570TL has a loud and best sound when listening to songs using earphones with AudioWizard, but unfortunately because when upgrading to android 8 the display it always lags and the speaker sound is small.
To listen to songs using earphones is satisfying.
08-18-2021 12:10 AM
08-20-2021 12:12 AM
Kuis Kiske@Kuis KiskeWW_Phone-15.02.1904.453
Yes, I use the latest version, and the screen display is still lag and slow.
When I use android 7 everything goes smoothly, when I upgrade to android 8 the screen display hangs out.
What should I do?
I can't downgrade to android 7.
