ZenFone Max M1 (not pro) Android 8-9 update failed
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-14-2020
07:47 AM
- last edited on
01-16-2024
04:23 PM
by
ZenBot
Hi, I updated my phone from Android 8 to Android 9. I downloaded the correct file from asus.com. after finished installing. The display is not showing, but the phone seems started, because if you press the volume, you can hear the sound. Also you can hear the sound when doing a screenshot.
The logo appears when starting.
Please help. Thank you!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-16-2020 12:19 AM
Hi switchfoot2093
Thank you for your asking. Kindly provide the information below so that we can better assist you.
1. Your previous firmware version
2. The firmware file which you downloaded
https://www.asus.com/supportonly/ZenFone%20Max%20M1%20(ZB555KL)/HelpDesk_BIOS/
3. Did you put the file into the root directory, aka the outermost place, of the internal storage?
Besides, please try the following steps to access recovery mode for the Factory Reset:
0. Try to back up your data with USB cable. If you can not access the phone, please check if your google account or microSD card have auto backup your data.
1. Power off the phone, then keep pressing "volume down key"
2. Press "power key" and stop press " power key" once you feel the vibration. Still keep pressing "volume down key".
3. Stop press "volume down key" once you enter [Android Recovery] Screen
4. Choose "Wipe data/factory reset">"Yes"
5. "Reboot system now"
#Hardware Reset Guide
https://www.asus.com/support/FAQ/1006346/
Please note that once the steps are completed, all data, apps, settings and personal information will be deleted.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-01-2020 02:38 AM
Yeah, I follow the correct steps on updating my Phone. I have 2 Zenfone Max M1, the same model. The other one updated successfully, but the other one did not. it finished updates but did not boot on OS, and no access on recovery mode.
I cannot go to Recovery Mode. My only access is CSC Fastboot Mode.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-01-2020 06:10 PM
Hi switchfoot2093
According to what you described, please bring your device to the nearest ASUS repair center for further device checking: https://www.asus.com/support/Service-Center-All-Countries/
If it is impossible to access the service center during Covid-19 period, please try Call us: https://www.asus.com/support/CallUs
