Features that should be added in asus zenfone max m2 After Android 10 stable update
bhupinder30363
1. Native call
2. Camera should improve ( i prefer gcam but if i compare gcam with stock stock quality is very bad)
3. Fingerprint should be optimised through updates it is a lil bit slow
4. Although asus has good bATTERY BACKUP but IDLE DRAIN should be solved.
5. Pubg with Hd+ medium or high ( i know you will say that this is not possible with snapdragon 632 but if we use gfx tool and play pubg on hd Then there is very less Lag ,it means even if they add it by updates It will be a good nothing its possible to play pubg on hd in snapdragon 632 cuz the difference is just 5 k antutu point (to 636)
6. If possible add hide apps option ( i had it in my previous phone which also had stock android )
7. AMBIENT DISPLAY FEATURE FOR NEW NOTIFICATION SHOULD BE ADDED
8. Asus have provided beta 1 and 2 for Asus max m2 now if they work on any 2 of these features and gave The phone last OS update (which may Satisy the users)
Thanks.
praveenrawat249
SPEAKER ,EARPHONE , BLUETOOTH SOUND QUALITY SHOULD BE OPTIMISED.
NATIVE VIDEO CALLING SHOULD BE ADDED.
REAR AND FRONT CAMERA QUALITY SHOULD BE OPTIMISED (add some good filters in camera also ).
BATTERY BACKUP SHOULD BE OPTIMISED (DRAINING FASTLY AFTER RESTARTING THE PHONE).
CHARGING SPEED SHOULD BE IMPROVE.
DEVICE HEATING ISSUE SHOULD BE FIXED.
QUICKSTEP LAUNCHER CRASH ISSUE SHOULD BE FIXED.
FAST FINGERPRINT AND FACE UNLOCK SERVICE.
CALL RECORDING OPTION SHOULD BE ADD.
IMPROVE BRIGHTNESS ISSUE.
ADD FINGERPRINT GESTURE TO SCROLL DOWN NOTIFICATION BAR .
IN FULL SCREEN GESTURE , SPACE OF NAVIGATION BAR AT BOTTOM OF SCREEN SHOULD BE REMOVE.
ON DARK MODE ,SOME TEXTS ARE NOT SEEM TO BE CLEAR.
3 FINGERS SWIPE SCREENSHOT AND SCREEN RECORDING OPTIONS SHOULD BE ADDED .
PLEASE GIVE US A STABLE UPDATE WITHOUT BUGS IN NEXT UPDATE.
Y_ASUS
Zen Master I
Hi bhupinder30363 & praveenrawat2499,
Is your phone ZB601KL or ZB630KL or ZB632KL?
Please provide your firmware version: Settings > About phone > Build number.
Thank you. 🙂
bhupinder30363
Y_ASUS
Thank you. 🙂
ZB632KL
