Bugs In Android 10 (Beta 2) For Asus Zenfone Max M2 ( WW-17.2018.2004.31 )
Luvgya
Rising Star I
Model Name: Asus Zenfone Max M2
Firmware Version: WW-17.2018.2004.31
Share The Bugs Here For This Update 🙏🙏
& Also What Are The Improvements
36 REPLIES 36
Vikhyat
Mukesh swami
List of bugs in beta 2 that I have encountered:-
1. Charging speed slow. Not exceeding 1000ma
2. Sometimes recent apps doesn't go away after clearing it again and again.
3. Speaker volume low. Headphone output low. Equalizer FX does not work with phone's speaker. It works with earphones.
4. The search bar in the app tray sometimes cuts in the notch area.
5. Smart lock option is not there in the settings.
6. Battery draining issue.
7. The dock icons are much higher as compared to Android pie.
8. Settings suggestions doesn't go away.
9. We cannot remove or edit the Google search bar on home screen.
10. There are multiple system apps like, circular, filled, gestural navigation bar, rounded etc
11. Third party launcher doesn't support gesture navigation
12. Video recording stuttering and video recording quality low. For 1080p it's 2.1MP, for 720p it's 0.9MP.
13. Notification ringtone changing back to the default one after reboot everytime .
Please fix all of these bugs and you won't be hearing any complains from us.
These are the main issues in the beta update. I hope Asus fixes these bugs.
Vikhyat
Some suggestions for the developers for the next release:
1. AMBIENT DISPLAY FEATURE FOR NEW NOTIFICATIONS SHOULD BE ADDED ( This was there in Android 9 builds)
2. SPEAKER ,EARPHONE , BLUETOOTH SOUND QUALITY SHOULD BE OPTIMISED
3. REAR AND FRONT CAMERA QUALITY SHOULD BE OPTIMISED
4. BETTER BATTERY BACKUP
5. PUBG HD GRAPHICS OPTION SHOULD BE ADDED
6. CALL RECORDING OPTION SHOULD BE ADDED IN GOOGLE DAILER APP (BECAUSE OTHER OEM BRAND LIKE NOKIA HAS ENABLED CALL RECORDING OPTION IN GOOGLE DAILER )
7. NEW BOOT ANIMATION SHOULD BE ADDED WITH LATEST ASUS ICON
8. FIX LOW DISPLAY BRIGHTNESS ISSUE ARISING AFTER ANDROID 10 BETA UPDATE
9. GESTURE FOR QUICKLY ACCESSING NOTIFICATION SHADE FROM THE HOME SCREEN.
ahmetse
My phone is more slower after the 2nd beta update of Android 10 a little optimization would be welcome.
Would have to change the interface come a modern Android 10 because the interface is not suitable for Android 10 it remains for Android 9.
It necessary to put back the applications of Asus because it remains an Asus all the same (this is just optional it's not important)
The battery does not hold any more then the fast charge does not change anything the charging of the phone is very long about 3 hours to be at 100%
They lack essential application I could not tell you which one.
I think there is a little problem when I listen to music the music goes by itself to the next one I didn't have that before the update I use the headphones that came with the phone.
We would have to see who is connected to our connection sharing because it only puts the number of devices.
Added some functionality which we did not expect.
There it is, I have no idea now haha. Thanks to reading me..
Good time to you
cpm25
Vikhyat
10.And please improve touch latency or touch response time. While moving my finger little faster the scrolling page doesn't match up speed with my finger. Almost all OEM's custom skin androids have this since past 4-5 yrs.
ZT-46b15773
Luvgya
  1. Model Name: Asus Zenfone Max M2
  2. Firmware Version: WW-17.2018.2004.31
There are so many bugs
