Bettery drain in Asus Max M2
Loh
Please fix it
Also. What about Android 10 update for Zenfone Max M2, this device will be getting Android 10 or not??
Y_ASUS
Zen Master I
Hi Loh,
Could you tell us your current firmware version? Settings > System > About phone > Build number
If you feel like the battery drains during using specific apps, we would suggest you test how much the app drains after using it for a certain time.
We would suggest you clear the background apps, and check how much battery is consumed from 100% after using the app for a certain time (e.g. 30 mins or 1 hour.)
Please show me a screenshot of the battery usage after testing.
Settings > Battery > Three dots on top right > Battery usage.
We haven't received information about the Android 10 update for ZB633KL.
You're welcome to stay tuned with us on our website for the latest information: https://www.asus.com/Phone/ZenFone-Max-M2/HelpDesk_BIOS/
Thank you 🙂
Loh
Y_ASUS
Hi Loh,
Thank you 🙂
Lasted firmware
Bettery usage
