Asus Zenfone max m1 touch not working properly
rpsurya8
Falcon_ASUS
@rpsurya8
If you are experiencing touch screen issues on your phone, we recommend restarting the device or performing a factory reset to check.
[Phone] How to do the factory reset on your phone
If the problem persists, it might be a hardware issue with the screen, and we suggest sending it in for further inspection and repair.
