Asus ZenFone 3 max
backuphjmp
Model: ZC520TL
RAM: 3GB
Firmware/App Version: Android 7.0 Nougat
Frequency of Occurrence: Everytime
Rooted: No
App Name:
Description: Hi all. I have on my ZenFone two SIM card : Nowo network Meo and Altice Meo network Meo. Why when I describe on dual sim settings the name of this network don' t appear - Altice Meo e Nowo, appear Meo Meo ? How correct this info. When receive sms I have same doubt where came from. Thanks for your help.
7 REPLIES 7
backuphjmp
I mean to say operator in stead " ..of this network.... "
ServiceE_Asus
Hi backuphjmp, Good day. Do you mean you rename the SIM description and the display not correct? Which firmware version are you currently on? Please also show me this error screenshot. Thank you.
backuphjmp
Last edited by backuphjmp on 2019/2/27 21:20 Hello Emile_asus. Thank you for answering so quickly. Yes it is this situation, I rename the sim card to Nowo and sim2 to Altice Meo I put the operator name and it does not change. It always has the name of the telecommunication network. The black screen is the sub menu settings on sms menu. Sending screen image. Send link with images : https://drive.google.com/file/d/1MczPNToqE0Y0-cVbePX2sWOSstss5LNb4g/view?usp=drivesdk https://drive.google.com/file/d/1XFbITKyiWOPPLUiXnMQqDXIl3tA81ReIJQ/view?usp=drivesdk https://drive.google.com/file/d/1VcJadVgn5PqpsBxOIG2CXtW1FKBiU16d8Q/view?usp=drivesdk Link for firmware https://drive.google.com/file/d/1AMomjMRto7lqrdHgaMia-KuK7ZOQBVBLPQ/view?usp=drivesdk Thanks for the help
backuphjmp
Hello Emile_asus. Thank you for answering so quickly. Yes it is this situation, I rename the sim card to Nowo and sim2 to Altice Meo I put the operator name and it does not change. It always has the name of the telecommunication network. The black screen is the sub menu settings on sms menu. Sending screen image. Send link with images : https://drive.google.com/file/d/ ... g/view?usp=drivesdk https://drive.google.com/file/d/ ... Q/view?usp=drivesdk https://drive.google.com/file/d/ ... Q/view?usp=drivesdk Link for firmware https://drive.google.com/file/d/ ... Q/view?usp=drivesdk Thanks for the help
