04-22-2020 08:51 PM
04-26-2020 12:01 AM
04-26-2020 12:29 AM
HamiltonAnd another bug is that I cannot find the file manager in app drawer..https://zentalk.asus.com/en/discussion/comment/75071#Comment_75071
And continuing to this..is there any fixes to the bugs mentioned..?
04-26-2020 03:55 AM
LuvgyaUnable to reset my phone,its showing "no command" alwayshttps://zentalk.asus.com/en/discussion/comment/74960#Comment_74960
You Need To Hard Reset Your Phone Before Update To This Software
And Do Not Forget To Remove Security Locks .
And After Update Also Needs To Hard Reset
Then It Will Be A Better OS
& if U Have enabled Camera2api in Android 9 Pie
Then In This Android 10 Developer Version Your Doesn't Going To Work Well
so Turn Off Ur Camera2api in Android 9 Then Go For Android 10 Developer
But Some Bugs Are Also There After These Process
Like Taking 4 To 5 Hours to Fully Charge Nd Battery Drain . A Small Bug in Stock Launcher
04-26-2020 05:12 AM
04-26-2020 07:35 AM
Pritam vermaI want to ask you do you have found a bug during video recording , video is lagging . Like some kind of frame dropsHii asus, after android 10 I am facing the problem of (stock camera). (1)The stock camera has very bad condition it's click a very dall and poor quality pictures and videos recording so bad on (front and rear) camera .(2) Stock camera Ui is very rubbish and icon has small I don't like this .(3)Not Add another feature like (panorama mode, time lapse,slo motion) and the (HDR mode) click very poor quality pictures . (4)The stock camera portrait mode on (front and rear) has not good ,it's click very bad pictures and the HD texture, details,sharpness all the stuff not working perfect and (5)noise reduction has not work. (6)Camera2api enable but gcam not support . I am sad too Asus android 10 stock camera.😭😭😭😭😭😭😭😭😭😭it's very bad asus.
(Battery issues): (1)Battery has drain issue has also here.(2) Battery backup not good and not perfect, Battery backup has so bad .(3) Battery after 15% low then system Ui lag and jitteriness issue .
(Navigation gesture issues) : (1)Navigation gesture not work properly.
(Dark mode and override force dark options issues):- Dark not not work perfectly I can enable dark mode then the dark text also dark and don't looking . This problem has I am also seeing the same another apps .
🙏🙏🙏🙏🙏🙏🙏Please please please please ASUS TEAM don't sleep ,fix these all issues randomly then Android 10 properly stable And then all users happy and love to you . Thanks 🙏🙏🙏🙏🙏🙏
