08-26-2020 12:31 AM
08-30-2020 06:42 AM
08-30-2020 08:13 AM
09-09-2020 09:24 PM
bijoyroy95just do this thing thenThanks for the reply. I looked into the dll option. It looked risky, messing around with the registry. Also, the phone isn't being registered at all. So problem might be different.
Thank you for reply. Unfortunately, it's not showing up in device manager 😞
09-26-2020 03:01 AM
sayyedsharuk55Thanks. It worked.hey bro.. i dont know if your problem is solved..
but here what you can do..
go to device manager..
plug your device with any cable(data transfer supportive)
now check which driver is shown in device manager..
if it showing a android device , then right click..
select update drivers
then select update driver manually..
select i have a disk
now there are 2 options..
google & something else driver
select something else instead of google..
then press update,finish whatever it is..
hope might help
10-26-2020 06:32 AM
