(ZB601KL)(MaxProM1) A10.v432 Update Review
RadeonPS
Rising Star II
(https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB601KL/UL-ASUS_X00T-WW-17.2017.2008.432-user.zip)(Turn on desktop site)
Updated from Beta3.v429 to Beta4.v432
QKQ1.WW_Phone-17.2017.2008.432-20200903
1.SOUND
V429 - 30% Bass
V432- 70% Bass
100% Bass after adb uninstalling of icepower (adb shell pm uninstall -k --user 0 dk.icepower.icesound )
2. No data loss after update
3. Gcam works ( MGC_7.3.020_Parrot043-v2.apk)
34 REPLIES 34
326akhil
Anandu
1.SOUND
V429 - 30% Bass
V432- 70% Bass
What about the storage!? Will it get cleared if not backed up, after the update ???
Please reply
Thank you
RadeonPS
Rising Star II
aman.rizwan00
Reboots into recovery instead of installing update
Resolved? Try apply update from storage when ut boots into recovery menu
Ankit Singh
https://zentalk.asus.com/en/discussion/36310/zb601kl-maxprom1-a10-v432-update-review
From which build no. You updated this firmare
Beta3.v429
anandtnair007@gmail.com
Hey I want to know whether gcam works perfectly or not
Till previous build gcam would stop taking photos after few clicks
Works fine for me bro even night sight.Mine is MGC_7.3.020_Parrot043-v2.apk
Ankit Singh
Are you facing any microphone problem
On build 424 we were not able to use mic while playing pubg mobile
Is this issue fixed ?
COD worked fine with mic in beta3.v429 for me. Didn't try COD now. Haven't played pubg.
326akhil
What about the files and apps? I mean, did the storage get cleared ,if not backed up, after the update?
Storage did not get cleared. Seem liked a perfect FOTA update.
326akhil
Please reply
Thank you
No, it most probably wont. Keep a backup anway.
Also Device certified
326akhil
Anandu
https://zentalk.asus.com/en/discussion/comment/117587#Comment_117587
https://zentalk.asus.com/en/discussion/comment/117673#Comment_117673
Beta3.v429
https://zentalk.asus.com/en/discussion/comment/117678#Comment_117678
https://zentalk.asus.com/en/discussion/comment/117782#Comment_117782
https://zentalk.asus.com/en/discussion/comment/117794#Comment_117794
https://zentalk.asus.com/en/discussion/comment/117815#Comment_117815
Thank you 😊
ashishrouth
Anandu
1.SOUND
V429 - 30% Bass
V432- 70% Bass
Device certified ?
Not applicable
What's about battery backup in A10 .432
