Why
vovaokhvat
When listening to music through headphones, the sound acquires the effect of echo
1 ACCEPTED SOLUTION
Accepted Solutions
Y_ASUS
Zen Master I
Hi vovaokhvat ,
This behavior is under investigation. In the meantime, if this is affecting your normal use greatly, you may choose to downgrade. You can find the file and instructions in the description "Version MaxProM1_downgrade_to_9": https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB601KL)/HelpDesk_BIOS/
Thanks for your understanding.
Y_ASUS
Zen Master I
Hi vovaokhvat ,
Could you tell us your ZenFone model and firmware version(Settings > About phone > Build number)? 🙂
What kind of sound has echo? Media/alarm/call/notification?
vovaokhvat
ZB602KL
QKQ1.WW_Phone-17.2017.2006.429-20200614
Media
Y_ASUS
Zen Master I
Hi vovaokhvat ,
