07-28-2020 10:08 AM
07-28-2020 10:40 AM
usakiyemAsus Moderators will not help or give any suggestions about custom ROMs. They will suggest to stay in stock version only.Please tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Hi moderator l try to install best custom rom from max Pro m1 give your suggestions
Asus max Pro m1 custom rom
07-28-2020 11:21 PM
07-29-2020 02:25 AM
Victor0_ASUSI unlocked many benefits on my Max pro m2 after unlocking boot loader. Lot of features I am enjoying in custom ROM can't be provided by ASUS even after a decade.Hi, you will not get updates via OTA if you unlock the bootloader, It's better if you keep your bootloader locked, your warranty will be void as soon as you unlock the bootloader. It does not necessarily mean that you are rooted, the bootloader can be unlocked without rooting but the processes go side by side. You will not get any benefit if you unlock bootloader and do not root.
08-03-2020 07:35 PM
vckanandvppNice I am happyhttps://zentalk.asus.com/en/discussion/comment/99851#Comment_99851
Even there are custom ROM's which provides monthly updates which are more stable than ASUS stock ROM . If I need to have any patch I can use it immediately with out begging ASUS.
