Why in the world is my zenfone max pro m1 battery drain is like a leaking bucket..
soorajrs22march
I had it.. what is this some kind of joke..? I can't use my phone for even 2 hrs now. A phone which lasted the entire day with full usage.. I used to watch 3-4 films in one single charge.
It shows 5 hrs left but it won't last even for 2 hours. Even if it does for 5 hrs is that all this phone had..? For 80% it gave more than 24 hrs of standby.
I don't know if asus has some kind of broken dictionary or something.. !!! the word UPDATE means to make improvements.. not to make it worse.. really if you can't do it right don't do it.. I mean no one is asking you to..! Everyime u bring out a new update patche something gets worse.. instead of bringing some new features u take away the things which was already there.. it's good to see asus still has a sense of humour.!!
This was a good phone.. one of the best I had.. the battery performance was the highlight.. and u ruined it.. thanku.. really helpful.. now I can't leave my home for more than 2-3 hours because the battery drains without any usage..
Either fix it or give me my refund.. you guys are the one who said about the great battery life. And I am not getting any now.. there nothing wrong with the battery.. it's just your useless updates.. so technically u destroyed the phone...
28 REPLIES 28
veeharish2005
Zen Master I
soorajrs22march
I don't know if asus has some kind of broken dictionary or something.. !!! the word UPDATE means to make improvements.. not to make it worse.. really if can't do it right don't do it.. I mean no one is asking.. everyime u bring out new update patches something gets worse.. instead bringing some new features u take away which which was already there.. it's good to see asus still has a sense of humour.!!
Can you do a battery calibration by following the instructions below
Discharge your phone fully until it turns itself off.
Turn it on again and let it turn itself off.
Plug your phone into a charger and, without turning it on, let it charge until the on-screen or LED indicator says 100 percent.
Unplug your charger.
Turn your phone on.
See if this have improved the situation or not.
soorajrs22march
It didn't do anything.. this update was the worse.. now the speaker is not working properly.. the battery drain is horrible.. just watching it will make u cringe.. hundreds of people have the same issue.. then why can't asus make a patch to fix this issue and calibrate along with it.. this is too much.. I have to worry about the battery always.. see the battery management.. 2 hrs.. without any use.. phone on idle..!!
AsusYouzr
Rising Star II
soorajrs22march
I didn't see this much drain on any post.
Only 1 hour 51 minutes backup remaining while phone is on 96% charge!
That's horrible.
mandaldipayan15
soorajrs22march
The things which you should do, are
1. Install Avast Cleanup. Give it it's full permission. And batch stop every app. It shall force stop every possible app.
2. Change the charging place. I.e. to plug the adapter to another wall socket.
3. Reboot to safe mode. And again reboot. Or charge the mobile in safe mode.
4. Reboot 5-6 times.
And the last, Factory reset. Which I wouldn't suggest....
Better I would suggest to DM AsusIndia via Instagram. They shall reply. I'm not an engineer neithera computer expert. But can assure you, they shall reply to you if you DM THEM. Atleast in my case, they did.
