Support for more launcher for nevigation gesture
vijayraobappu
Support for more launcher for nevigation gesture like new pixel phones are supporting
I searched on Google and get that action launcher v45 and up is supported for nevigation gesture on most devices
So i downloaded v46.5beta and v45 and boom i see that both are not working on our asus zenfone max pro m1 (X00TD)
So kindly add this feature
Thaks in advance
25 REPLIES 25
RadeonPS
Rising Star II
Christine_ASUS
Hi sashastav84
Thank you for your reply. The Action Launcher supports Gesture Navigation in my MPM1 with WW-17.2017.2008.432.
Kindly try some stay-at-home troubleshooting tips below:
1. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
2. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
If the issue persists, kindly provide me the video of your issue for further checking.
Recent apps not working. Also how is the AM/PM in upper case. Mine isn't.
Wish it was supported in "Lawnchair" launcher. And "Shade Launcher". Both are pixel like.
Christine_ASUS
Hi sashastav84
To avoid any misunderstanding, do you mean that you have the issue about the gesture below?
Swipe up>App Apps
Recent apps
6pslima2002
Christine_ASUS
Hi sashastav84
@Christine_ASUS Hi, I just tried Gesture Navigation on Action Launcher on the latest 432 firmware. Even on my MPM1, the Recent Apps functionality doesn't work. Sadly, this means I have to stick to the stock launcher. Hopefully Google will fix this soon.
vijayraobappu
Relly shem on asus not working gesture nevigation on this latest update on custom launcher
vijayraobappu
I am just crying for why i buyer this phone
I installed action launcher and when i gesture the pill upward the recent app directly go through display🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣
