Support for more launcher for nevigation gesture
vijayraobappu
Support for more launcher for nevigation gesture like new pixel phones are supporting
I searched on Google and get that action launcher v45 and up is supported for nevigation gesture on most devices
So i downloaded v46.5beta and v45 and boom i see that both are not working on our asus zenfone max pro m1 (X00TD)
So kindly add this feature
Thaks in advance
25 REPLIES 25
Christine_ASUS
Community Legend II
Hi sashastav84
Thank you for your reply. The Action Launcher supports Gesture Navigation in my MPM1 with WW-17.2017.2008.432.
Kindly try some stay-at-home troubleshooting tips below:
1. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
2. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
If the issue persists, kindly provide me the video of your issue for further checking.
sashastav84
Christine_ASUS
Hi sashastav84
Try recent apps now. Work? NO))) u cant swype between apps by Gesture
Christine_ASUS
Community Legend II
Hi sashastav84
To avoid any misunderstanding, do you mean that you have the issue about the gesture below?
Swipe up>All Apps
veeharish2005
Zen Master I
Christine_ASUS
Hi sashastav84
Swipe up>App Apps
I think he is having issues with recent apps
sashastav84
veeharish2005
https://zentalk.asus.com/en/discussion/comment/118022#Comment_118022
Yes, recent apps
