08-27-2020 12:37 AM
08-28-2020 06:02 AM
sashastav84How did you remove chrome since you cannot delete chrome app because it is a preloaded app?https://zentalk.asus.com/en/discussion/comment/107144#Comment_107144
Now I'm on android 9 084, there are no such problems. And on all versions of android 9 there are no problems. On android 10, this is on all versions. I understand that this is the AOSP version and I cannot delete the search bar, but this bar launches the chrome app. After removing the chrome, the bar becomes different and launches the google app, but its design is not google app.
08-28-2020 06:08 AM
veeharish2005Facepalm..... лютый фейспалм.https://zentalk.asus.com/en/discussion/comment/107150#Comment_107150
08-28-2020 08:54 AM
sashastav841. You cannot change a chrome widget into Google app widget.https://zentalk.asus.com/en/discussion/comment/107242#Comment_107242
There is a google app and google chrome for android. I always use the google app search engine. But on android 10 I have the default search bar chrome. I understand that I cannot delete the search, but I cannot change it to google app. In the Indian version, everyone has a Google app search by default, in the Russian version, chrome search is set by default. Moreover, this only applies to 10 android. Many do not see the difference in Russia because they use yandex. I can also turn off chrome and only then the widget launches the google app. But that's not okay.
08-28-2020 09:10 AM
veeharish2005nothing new. I will wait for the answer of the moderatorhttps://zentalk.asus.com/en/discussion/comment/107248#Comment_107248
2. Asus could have made the widget to redirect the user to Google app if the widget could not detect chrome app or any app which could handle the request.(this would save the launcher from crashing if the user have disabled or some how managed to delete chrome app).
3. This could be a design choice specific for the Russian sku.
08-31-2020 01:56 AM
