12-30-2020 08:04 AM
01-01-2021 09:18 AM
RadeonPSThank youhttps://zentalk.asus.com/en/discussion/42616/remove-settings-suggestions
if you want it removed, try this adb.
adb shell pm uninstall -k --user 0 com.android.settings.intelligence
note that this will also remove search bar of settings.and will look like this
01-01-2021 01:59 PM
aparajitlal.kumarThey will not do any changes. This is what we have now, the same will be in if any future update with next latest security patch.https://zentalk.asus.com/en/discussion/comment/143998#Comment_143998
Thank you
This is not the one, we need, already tried and reverted back.
I have another mobile from moto, which has Android asop. But the suggestions are removable in that.
May be it need to be enabled in Android asop as well by asus devs, but not sure, if this will be fixed as it looks to be low priority than other bugs
01-01-2021 02:03 PM
aparajitlal.kumarAOSP has lot options that Asus can modify and give the best firmware. But, they will not spend time in this old useless device now(They will not get profit/No sales).https://zentalk.asus.com/en/discussion/comment/143998#Comment_143998
Thank you
01-02-2021 02:30 AM
07-12-2022 11:38 AM
