Regarding gesture navigation in android 10 is there any way to fix the black area at bottom
aswinsuri97
Model Name:zenfone max pro m1
Firmware Version: android 10
Rooted or not:not
Frequency of Occurrence:
======================================== while using gesture navigation in some apps like instagram,some bottom area is blacked out which feels really weird,i heard that u can adjust that in developer options but i havent found out it yet
1 ACCEPTED SOLUTION
Accepted Solutions
nidhin3
Zen Master I
Make dpi size to 410 in developer option.
5 REPLIES 5
nidhin3
Zen Master I
Vinay_b
aswinsuri97
  1. Model Name:zenfone max pro m1
  2. Firmware Version: android 10
  3. Rooted or not:not
  4. Frequency of Occurrence:
Can u share the screenshot of the same
rahulkewlani199
Rising Star I
aswinsuri97
that developer setting is for the one who uses small display size (by default its normal)
for that u need to change the dpi to 410 from 360
but i would personally recommend u to download "fluid navigation gesture" app
with that u can hide the default navigation bar and then can customize gesture as per ur need
aswinsuri97
rahulkewlani1996
https://zentalk.asus.com/en/discussion/27930/regarding-gesture-navigation-in-android-10-is-there-any...
U need to use adb right maybe will try it out
