problem after update firmware on may 2020, asus zenfone max pro m1
Sumarsono
After update zenfone max pro m1 to new firmware a few days ago,, my phone sometimes cannot receive call can cannot receive sms in same times,, but when its eror i still can send whatsaap and browsing,,
Christine_ASUS
Community Legend II
Hi Sumarsono
Thank you for your sharing. Kindly provide the information below so that we could better assist you.
1. Could you tell us the name of the carriers you've tried that have this problem? Will the phone work with SIM cards by other carriers?
Also, please try "safe mode" to see if the issue remain:
2. Could you receive /send calling, text, SMS?
3. Which SMS app you use? Also, please provide the app version.
4. If you could not send SMS in tripartite apps, are you using via the Internet(4G), the Wi-Fi, or both? Will it work with other Internet channel? Does the phone operate in the stable signal? Where's the approximate location that this problem appears in?
Please try to reset Network: Setting>System>Reset options>Reset W+K95i-Fi, mobile & Bluetooth
5. Please check if the phone storage is ok. Setting>Storage & memory
6. Did the phone break or fall before?
