10-17-2020 08:32 AM - last edited on 01-16-2024 12:33 AM by ZenBot
10-20-2020 03:44 AM
Sandeep KumarEven my nokia 6.1 plus with Snapdragon 636 doesn't have carrier aggression.please check qualcomm site
those companies who wants enable carrier aggregation enable in their devices should pay more charges that's why
this its not hardware limitation.
The Snapdragon 636 has support for Bluetooth 5.0. It has the Snapdragon X12 LTE modem, which can achieve up to 600Mbps downlink and up to 150Mbps uplink. On the modem side, it also supports 3x20MHz carrier aggregation and up to 256-QAM for downlink, and 2x20MHz carrier aggregation up to 64-QAM for uplink.
10-20-2020 04:38 AM
veeharish2005I am not talking about 5G first of all and for your kind information india is not ready for 5G at all.https://zentalk.asus.com/en/discussion/comment/125670#Comment_125670
It supports, but it doesn't matter if the antenna in the device doesn't support carrier aggression.
Support doesn't mean anything, 5g devices sold in india doesn't have the mmwave 5g antenna which means that the device cannot connect to mmwave 5g network which is a lot faster than sub 6 ghz 5g ,but the x55 modem supports mmwave 5g.
And Snapdragon 865 supports 145hz refresh rate but not all device with Snapdragon 865 have a 145hz display.
10-20-2020 04:41 AM
veeharish2005but nokia 7.1 with sd 636 supports carrier aggregation. matters only cost which can given by the companies to sd using the services of carrier aggregation.https://zentalk.asus.com/en/discussion/comment/125670#Comment_125670
10-20-2020 04:43 AM
Sandeep Kumarbut on nokia forum some moderator also said that nokia 6.1 plus may also be support carrier aggregation in upcoming updates.https://zentalk.asus.com/en/discussion/comment/125971#Comment_125971
10-20-2020 05:27 AM
Sandeep Kumar1. I gave it as an example to say that not all the mentioned support in Qualcomm's website will be in a device with the processor.https://zentalk.asus.com/en/discussion/comment/125698#Comment_125698
SD 865 supports 144hz not 145hz refresh rate with QHD+ display and 60 hz with 4k and not companies uses higher refresh rate because of cost of the display cost.
Sandeep KumarNokia 7.1 supports carrier aggression because it has a superior antenna compared to nokia 6.1 plus.https://zentalk.asus.com/en/discussion/comment/125971#Comment_125971
Sandeep KumarNo, nokia 6.1 plus does not support carrier aggression. Here is a discussion from nokia forum created one month agohttps://zentalk.asus.com/en/discussion/comment/125991#Comment_125991
