Please Enable Carrier Aggregation on Max Pro M1 in upcoming update
Sandeep_Kumar
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
17 REPLIES 17
VEL_ASSA
Rising Star II
Asus not provide carrier aggregation on ASUS ZENFONE MAX PRO M1.
victor010
Zen Master III
Hi there, it is an hardware limitation.
Sandeep_Kumar
please check qualcomm site
those companies who wants enable carrier aggregation enable in their devices should pay more charges that's why
this its not hardware limitation.
The Snapdragon 636 has support for Bluetooth 5.0. It has the Snapdragon X12 LTE modem, which can achieve up to 600Mbps downlink and up to 150Mbps uplink. On the modem side, it also supports 3x20MHz carrier aggregation and up to 256-QAM for downlink, and 2x20MHz carrier aggregation up to 64-QAM for uplink.
veeharish2005
Zen Master I
Sandeep Kumar
It supports, but it doesn't matter if the antenna in the device doesn't support carrier aggression.
Support doesn't mean anything, 5g devices sold in india doesn't have the mmwave 5g antenna which means that the device cannot connect to mmwave 5g network which is a lot faster than sub 6 ghz 5g ,but the x55 modem supports mmwave 5g.
And Snapdragon 865 supports 145hz refresh rate but not all device with Snapdragon 865 have a 145hz display.
