Phone not charging.
I'm also facing same issue with my Asus Zenfone pro max m1 after last update.
Phone not getting charged with Asus charger or data cable connected to laptop/PC.
When I switch it off , only then it start charging with both Charger and datacable and continue to charge even on swithcing it ON, but it displays Reverse charging window/notification pop-up. (I have to do it every time during charging)
If remove the charger and re-connect the charger, it again stops charging.
victor010
Zen Master III
 Hey, we would like to assist you at our service  centre. Find your nearest center at: https://www.asus.com/in/support/Service-Center/India.
