Phone ia not charging.
I have Zenfone Maxpro M1 which recently started a weird behaviour. it is not charging when I put it on charge as I'm using official Charger and Cable provided by company.
Built Number 082, May update.
Kindly help me.
veeharish2005
Zen Master I
priyabrata7537
Kindly help me.
Try with other charger.
gauravg76531
i have too this problem and its weird
everything like hardware and charger is ok but shows charging but not charging
victor010
Zen Master III
Hi there, kindly follow the below steps:
1 . Kindly try using another charger and see if it helps.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
