Notifications not working
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-10-2020
03:37 AM
- last edited on
01-16-2024
01:26 AM
by
ZenBot
Hi, I recently bought a Zenfone Max Pro M2, and the notification led doesn't work. I went to notification settings and activate the blinking light, but nothing happens. It only works when my battery is low, then the red light turns on.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-12-2020 02:36 AM
alvaro321Follow the below mentioned steps :Hi, I recently bought a Zenfone Max Pro M2, and the notification led doesn't work. I went to notification settings and activate the blinking light, but nothing happens. It only works when my battery is low, then the red light turns on.
Go to settings,
Tap on "Display",
Tap on "Advanced",
Scroll down a little and look for an option called "Blink Light",
Turn ON that option by tapping on the radio button available beside that "Blink Light" option.
The above mentioned steps should fix your issue and you would see blinking notification light when any notification pops up like whatsapp message or text messages or mails etc.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-12-2020 10:42 PM
Hi alvaro321,
If you’ve made sure you enabled blink light on the app, and there’s still no LED light, we suggest that you bring your phone to your local service center for a check: https://www.asus.com/support/Service-Center-All-Countries/
Thank you 🙂
Thank you 🙂
