New update on Max pro m2 ZB630KL/ZB631KL
Riju9547
Rising Star II
Model Name: ZB630KL/ZB631KL
Firmware Version:WW-17.2018.2004.424
Rooted or not: NO
Frequency of Occurrence:None
APP Name & APP Version (If your issue relates to the app):None
Did anyone installed the latest update of android 10 in Max Pro M2? Please confirm you your are having any problem or not. And i need the answer of the following-
Did you loose any data
What is your device model name and country name?
Is there any major problem?
Please share the experience of sound output.
Mention the fixes if any
14 REPLIES 14
arpand06
Nothing changed in sound output to headphone, the same hollow sound with no bass whatsoever.
albertkes
Rising Star I
Riju9547
  1. Model Name: ZB630KL/ZB631KL
  2. Firmware Version:WW-17.2018.2004.424
  3. Rooted or not: NO
  4. Frequency of Occurrence:None
  5. APP Name & APP Version (If your issue relates to the app):None
  1. Did you loose any data
  2. What is your device model name and country name?
  3. Is there any major problem?
  4. Please share the experience of sound output.
  5. Mention the fixes if any
424th firmware.
1.When upgrading from the 409th, I did not lose the data.
2. Asus Zenfone Max Pro (M2) ZB631KL, Russia.
3. There are no problems so far.
4. The sound in the headphones without bass, but on the 409th, too, at first, a couple of days, there was no bass, then the sound became normal.
5. In the curtain, the location of the icons was fixed, and the screen seemed to become more responsive.
Amar_jyoti
Rounded corners have not been fixed in this new update
jenkinsj9299
I didn't yet got the update
