07-22-2020 02:53 AM
07-23-2020 11:42 AM
suvankar0786Just tap on the link below
My serial number
07-23-2020 11:39 PM
07-24-2020 09:28 PM
victor2020Can you solve these issues to each and every user of asus then we go to service center, Say FirstHi, we suggest you to please visit the nearest ASUS service center for better assistance. Locate here : https://www.asus.com/in/support/Service-Center/India
07-24-2020 09:29 PM
parvezalam01994Yes bro you r rightYeah, the 1st bug isn't new. It was already there before the update. Happens with me all the time if I minimise large apps like pubg while it is still loading. The screen would freeze for a moment and that error msg pops up. That is really bcuz of the buggy UI. It is also the bad UI that doesn't allow me the double tap wakeup while screen is locked, also the finger print unlock not working arises due to bad UI. Because, if the screen is wake and locked, then the fingerprint works fine. But, as soon as the screen is locked the fingerprint doesn't work sometimes.
Just a freaking bad UI, the so called near stock UI my foot.
07-27-2020 11:52 AM
Victor0_ASUSI need a perfect solution Ok, I already visited service center in past. When my device cover under warranty at that time also I am facing same issue and now also I am facing same issue. So At the end Your service center also like your device. I need solutionHi, we suggest you to please visit the nearest ASUS service center for better assistance. Locate here : https://www.asus.com/in/support/Service-Center/India
